Best practice to run php tests on branches and docker build on tags
Andrei Dascalu
I have a PHP project (basic, with composer). I would like that when team members make a merge requests, there would be a pipeline that simply runs phpunit while on tags following a certain pattern there would be a docker build for an image that is then pushed.
Now the second part is already up and running, using
image: atlassian/default-image:2
pipelines:
tags: v*:
- step:
services:
- docker
script:
- ... run docker build and push
So my question is:
is there a way to use another image for my purpose in the same pipeline file? From what I can see, I can't have two pipeline yml in the same project.
From what I gather, my next choice would be to run some docker commands against my own custom Docker image.
Halyna Berezovska
November 13, 2020
@Andrei Dascalu you can'have two pipelines yaml, but you can write different steps.
For example, you want to execute dev-test step and generally it is executed step master-test.
Regarding this,
you can execute some steps you desire on tags also, not on branches only. Look at the doc how to configure pipeline code and use tags
https://support.atlassian.com/bitbucket-cloud/docs/configure-bitbucket-pipelinesyml/
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
