Bit-Booster commit graph doesn't display
Tom McCallum January 11, 2017
Hi all. We are using Bit-Booster commit graph  2017.1.10 and although it works for most repositories there are some large ones that it doesn't display.  I'm wondering if there is something I can look for a clue to why this might be happening. Any advice very much appreciated.
Thank you for the clue. The server is SUSE 11 sp3 Linux x86_64. It’s only happening on the ‘All Branches Graph’ the commits screen works. Here is what the console log from Chrome looks like:
Thanks again!
internal-node-modules-atlassian-aui-src-js-aui-internal-deprecation.js?_statichash=312b68f7e84ba102…:1 DEPRECATED JS - Cookie has been deprecated since 5.8.0 and will be removed in a future release. Use cookie instead.
     at b.default (https://stash.us.cray.com/s/312b68f7e84ba102c83c55a5bac998c1-CDN/-131123793…ec3ac64fb81/_/download/contextbatch/js/_super/batch.js?locale=en-US:54:209)
k @ internal-node-modules-atlassian-aui-src-js-aui-internal-deprecation.js?_statichash=312b68f7e84ba102…:1
eve.js?_statichash=312b68f…-CDN%2F-1311237930%2Fc721a6c%2F1%2Fd233379505bd3…:5 DEPRECATED - requiring 'eve' has been deprecated since AUI 5.7 and will be removed in AUI 6.0.
(anonymous) @ eve.js?_statichash=312b68f…-CDN%2F-1311237930%2Fc721a6c%2F1%2Fd233379505bd3…:5
internal-node-modules-atlassian-aui-src-js-aui-internal-deprecation.js?_statichash=312b68f7e84ba102…:1 DEPRECATED JS - Dialog constructor has been deprecated and will be removed in a future release. Use Dialog2 instead.
     at new o (https://stash.us.cray.com/s/53d094ae0f28f6624be02f0163717e24-T/-1311237930/…&nps-enabled=true&nps-not-opted-out=true&supportedApplication=true:425:544)
internal-node-modules-atlassian-aui-src-js-aui-internal-deprecation.js?_statichash=312b68f7e84ba102…:1 DEPRECATED JS - Dialog popup constructor has been deprecated and will be removed in a future release.
     at f.<anonymous> (https://stash.us.cray.com/s/312b68f7e84ba102c83c55a5bac998c1-CDN/-131123793…ec3ac64fb81/_/download/contextbatch/js/_super/batch.js?locale=en-US:59:260)
10internal-node-modules-atlassian-aui-src-js-aui-create-element.js?_statichash=312b68f……:1 AJS's create element functionality has been deprecated since 5.9.0.
No alternative will be provided.
Use document.createElement() or jQuery.parseHTML(), or preferably use a templating library.
a.default @ internal-node-modules-atlassian-aui-src-js-aui-create-element.js?_statichash=312b68f……:1
internal-node-modules-atlassian-aui-src-js-aui-internal-deprecation.js?_statichash=312b68f7e84ba102…:1 DEPRECATED JS - Inline dialog constructor has been deprecated and will be removed in a future release. Use inline dialog 2 instead.
     at HTMLDocument.<anonymous> (https://stash.us.cray.com/s/53d094ae0f28f6624be02f0163717e24-T/-1311237930/…&nps-enabled=true&nps-not-opted-out=true&supportedApplication=true:5409:86)
commits:187 Uncaught SyntaxError: Unexpected token  in JSON at position 58832
    at JSON.parse (<anonymous>)
    at Function.g (cool.js?_statichash=53d094a…-T%2F-1311237930%2Fc721a6c%2F1%2F69d7d79e6648b3…:902)
    at XMLHttpRequest.drawGraph (cool.js?_statichash=53d094a…-T%2F-1311237930%2Fc721a6c%2F1%2F69d7d79e6648b3…:1505)
G__Sylvie_Davies__bit-booster_com_
January 11, 2017
"All Branches Graph" or integrated graph on commits screen or both?   Anything in your browser's javascript console logs?  (e.g., ctrl + shift + c in chrome, then click on "console" tab)
p.s.  do you run Bitbucket server on windows or on linux?
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
