I am trying to write a YAML pipeline script to deploy files that have been altered from my bitbucket repository to my remote server using ssh keys. The document that I have in place at the moment was copied from bitbucket itself and has errors:
pipelines: default: - step: name: Deploy to test deployment: test script: - pipe: atlassian/sftp-deploy:0.3.1 - variables: USER: $USER SERVER: $SERVER REMOTE_PATH: $REMOTE_PATH LOCAL_PATH: $LOCAL_PATH
I am getting the following error
Configuration error
There is an error in your bitbucket-pipelines.yml at [pipelines > default > 0 > step > script > 1]. To be precise: Missing or empty command string. Each item in this list should either be a single command string or a map defining a pipe invocation.
My ssh public and private keys are setup in bitbucket along with the fingerprint and host. The variables have also been setup.
How do I go about setting up my YAML deploy script to connect to my remote server via ssh and transfer the files?
There is a problem with your yaml configuration. You need to indent some things.
Here is the fixed example. I also bumped the sftp deploy pipe version:
pipelines:
default:
- step:
deployment: test
script:
- pipe: atlassian/sftp-deploy:0.4.0
variables:
USER: $USER
SERVER: $SERVER
# SSH_KEY: '<string>' # Optional.
# EXTRA_ARGS: '<string>' # Optional.
# DEBUG: '<boolean>' # Optional.
