×I downloaded BitBucker Server yesterday and it started without any error the first time. I left it running overnight and when I looked this morning, I saw that the server had stopped with a timeout error.
I tried to start it again, but it keeps failing with a timeout error. I updated the start-webapp.sh script with: JVM_SUPPORT_RECOMMENDED_ARGS="-Datlassian.plugins.enable.wait=360" but it hasn't made a difference. These are the logs I'm getting:
2020-09-15 11:26:24,736 INFO [main] c.a.b.i.b.BitbucketServerApplication Starting BitbucketServerApplication on PD-ORB-TSTST01 with PID 420344 (C:\Users\chrgil\Atlassian\Bitbucket\7.5.2\app\WEB-INF\classes started by chrgil in C:\Users\chrgil\Atlassian\Bitbucket\7.5.2\bin)
2020-09-15 11:26:24,737 INFO [main] c.a.b.i.b.BitbucketServerApplication The following profiles are active: windows
2020-09-15 11:26:25,503 INFO [main] c.a.b.i.boot.log.BuildInfoLogger Starting Bitbucket 7.5.2 (2bee18b built on Wed Sep 09 19:14:34 NZST 2020)
2020-09-15 11:26:25,504 INFO [main] c.a.b.i.boot.log.BuildInfoLogger JVM: Oracle Corporation Java HotSpot(TM) 64-Bit Server VM 1.8.0_241-b07
2020-09-15 11:26:27,511 INFO [main] c.a.b.i.b.BitbucketServerApplication Started BitbucketServerApplication in 4.734 seconds (JVM running for 7.279)
2020-09-15 11:26:32,081 INFO [spring-startup] c.a.s.internal.home.HomeLockAcquirer Successfully acquired lock on home directory C:\Users\chrgil\Atlassian\ApplicationData\Bitbucket
2020-09-15 11:26:39,856 INFO [spring-startup] c.a.s.internal.home.HomeLockAcquirer Successfully acquired lock on home directory C:\Users\chrgil\Atlassian\ApplicationData\Bitbucket\shared
2020-09-15 11:26:42,973 WARN [spring-startup] com.hazelcast.instance.Node [10.51.20.194]:5701 [chrgil] [3.12.6] No join method is enabled! Starting standalone.
2020-09-15 11:27:02,957 INFO [spring-startup] c.a.s.i.s.g.t.DefaultTranscodeServer Callback socket listening at 127.0.0.1:64281
2020-09-15 11:27:11,912 INFO [spring-startup] c.a.s.i.h.s.WindowsHookScriptCommandLineFactory Found GNU bash at C:\Users\chrgil\AppData\Local\Programs\Git\bin\bash.exe
2020-09-15 11:27:14,137 INFO [spring-startup] c.a.s.i.hook.DefaultHookService Hook callback socket listening on 127.0.0.1:64798
2020-09-15 11:27:17,018 INFO [spring-startup] c.a.s.i.s.g.h.DefaultGitHookService Git hook callback socket listening on 127.0.0.1:64800
2020-09-15 11:27:20,917 WARN [FelixStartLevel] o.e.g.b.e.i.s.ExtenderConfiguration Gemini Blueprint extensions bundle not present, annotation processing disabled.
2020-09-15 11:27:34,902 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /extension/build-status/ in bundle com.atlassian.bitbucket.server.bitbucket-frontend; it does not exist
2020-09-15 11:27:35,751 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/plugin/connect/confluence/ in bundle com.atlassian.plugins.atlassian-connect-plugin; it does not exist
2020-09-15 11:27:35,821 WARN [spring-startup] c.a.p.c.r.OsgiBundledPathScanner Cannot scan directory /page/ in bundle com.atlassian.bitbucket.server.bitbucket-policies as it does not exist
2020-09-15 11:27:35,844 WARN [spring-startup] c.a.p.c.r.StaticPluginPathScanner Cannot scan directory /static/bitbucket/internal/feature/admin/ratelimit/ in web static as it does not exist
2020-09-15 11:27:37,926 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/oauth/shared/servlet/ in bundle com.atlassian.oauth.atlassian-oauth-service-provider-plugin; it does not exist
2020-09-15 11:27:38,177 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/oauth/shared/servlet/ in bundle tac.bitbucket.languages.de_DE; it does not exist
2020-09-15 11:27:38,179 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /extension/build-status/ in bundle tac.bitbucket.languages.de_DE; it does not exist
2020-09-15 11:27:38,185 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/oauth/shared/servlet/ in bundle tac.bitbucket.languages.fr_FR; it does not exist
2020-09-15 11:27:38,185 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /extension/build-status/ in bundle tac.bitbucket.languages.fr_FR; it does not exist
2020-09-15 11:27:38,275 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/oauth/shared/servlet/ in bundle tac.bitbucket.languages.ja_JP; it does not exist
2020-09-15 11:27:38,276 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /extension/build-status/ in bundle tac.bitbucket.languages.ja_JP; it does not exist
2020-09-15 11:27:38,386 INFO [spring-startup] c.a.b.internal.ssh.server.SshServer Starting SSH server on port 7999...
2020-09-15 11:27:38,576 INFO [spring-startup] c.a.b.internal.ssh.server.SshServer Started SSH server successfully.
2020-09-15 11:27:38,844 INFO [spring-startup] c.a.b.i.s.c.j.c.HealthCheckRunner New health check registered: AuthenticationCheck
2020-09-15 11:27:38,845 INFO [spring-startup] c.a.b.i.s.c.j.c.HealthCheckRunner New health check registered: VersionCheck
2020-09-15 11:27:38,852 INFO [spring-startup] c.a.b.i.s.i.e.DefaultIndexEventQueueProcessor Event queue processor has been started
2020-09-15 11:27:38,852 INFO [spring-startup] c.a.b.i.s.c.j.c.HealthCheckRunner New health check registered: KnownIssueCheck
2020-09-15 11:27:38,929 INFO [spring-startup] c.a.b.i.s.c.c.DefaultClusterJobManager Registering job for StartupChecksJob
2020-09-15 11:27:38,947 INFO [spring-startup] c.a.b.i.s.c.c.DefaultClusterJobManager Registering job for ElasticsearchSynchronizeJob
2020-09-15 11:27:38,956 INFO [spring-startup] c.a.b.i.s.c.j.c.HealthCheckRunner New health check registered: SearchIndexCheck
2020-09-15 11:27:39,149 INFO [spring-startup] c.a.s.internal.scm.PluginScmService Bitbucket is using C:\Users\chrgil\AppData\Local\Programs\Git\cmd\git.exe version 2.28.0
2020-09-15 11:27:54,142 INFO [Caesium-1-3] c.a.b.i.s.i.jobs.StartupChecksJob Running startup jobs for search
2020-09-15 11:28:28,962 WARN [Caesium-1-2] c.a.a.c.h.r.RemoteHashingInstructionsReader Unable to read remote instructions with key 'uid.onewayhash'.
2020-09-15 11:28:28,963 WARN [Caesium-1-2] c.a.a.c.h.BcryptAnalyticsEmailHasher No instructions for hashing could be found.
2020-09-15 11:29:09,044 WARN [UpmScheduler:thread-1] com.atlassian.upm.pac.PacClientImpl Error when querying application info from MPAC: com.atlassian.marketplace.client.MpacException: org.apache.http.conn.ConnectTimeoutException: Connect to marketplace.atlassian.com:443 [marketplace.atlassian.com/13.236.8.160, marketplace.atlassian.com/13.236.8.159, marketplace.atlassian.com/13.236.8.158] failed: connect timed out
yes. Bitbucket (7.21.7) keeps not finding stuff
2022-12-01 14:03:28,717 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /extension/build-status/ in bundle com.atlassian.bitbucket.server.bitbucket-frontend; it does not exist
2022-12-01 14:03:29,250 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/plugin/connect/confluence/ in bundle com.atlassian.plugins.atlassian-connect-plugin; it does not exist
2022-12-01 14:03:29,325 WARN [spring-startup] c.a.p.c.r.OsgiBundledPathScanner Cannot scan directory /page/ in bundle com.atlassian.bitbucket.server.bitbucket-policies as it does not exist
2022-12-01 14:03:29,340 WARN [spring-startup] c.a.p.c.r.StaticPluginPathScanner Cannot scan directory /static/bitbucket/internal/feature/admin/ratelimit/ in web static as it does not exist
2022-12-01 14:03:30,220 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/oauth/shared/servlet/ in bundle com.atlassian.oauth.atlassian-oauth-service-provider-plugin; it does not exist
2022-12-01 14:03:30,493 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/oauth/shared/servlet/ in bundle tac.bitbucket.languages.de_DE; it does not exist
2022-12-01 14:03:30,495 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /extension/build-status/ in bundle tac.bitbucket.languages.de_DE; it does not exist
2022-12-01 14:03:30,498 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/oauth/shared/servlet/ in bundle tac.bitbucket.languages.fr_FR; it does not exist
2022-12-01 14:03:30,499 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /extension/build-status/ in bundle tac.bitbucket.languages.fr_FR; it does not exist
2022-12-01 14:03:30,502 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /com/atlassian/oauth/shared/servlet/ in bundle tac.bitbucket.languages.ja_JP; it does not exist
2022-12-01 14:03:30,503 WARN [spring-startup] c.a.s.i.p.s.OsgiBundledPathScanner Cannot scan directory /extension/build-status/ in bundle tac.bitbucket.languages.ja_JP; it does not exist
any answer ? =)
