BitBucket scriptrunner create project
Alberto Medina
December 3, 2019
   I am trying to create a new BitBucket project using scriptrunner. There seem to be a lack of examples on this and I am very confused by the documentation.
The idea is to have something working on the Script console that then I can use as a built it script.
I have tried using ProjectCreateRequest.Builder but in all honesty I cannot make sense of how to create an instance in order to pass it as a parameter to a ProjectService "create" method,  I am not able to pass the static type checking.
Does anyone have an example of give me some pointers on how this will work?
Robert Giddings _Adaptavist_
Hi Alberto,
Please try the following script in the Script Console, which in this example creates a new project with the key "NEW" and name "New Project".
import com.atlassian.sal.api.component.ComponentLocator
import com.atlassian.bitbucket.project.ProjectService
import com.atlassian.bitbucket.project.ProjectCreateRequest
ProjectService projectService = ComponentLocator.getComponent(ProjectService)
projectService.create(new ProjectCreateRequest.Builder().key("NEW").name("New Project").build())
I hope this helps answer your question?
Robert Giddings
Alberto Medina
December 5, 2019
Yes, it does, thanks you
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
