Sign up Log in
Bitbicket cannort be strated with error SpringMVC dispatcher [springMvc] could not be started
Nadica Gaber
Hi All,
We are running the Teams in Space environment for presentations.  All application were working fine, but after restart, bit bucket won't start.
The error from the logs:
2018-09-17 09:38:08,763 ERROR [spring-startup] c.a.j.s.w.s.JohnsonDispatcherServlet SpringMVC dispatcher [springMvc] could not be started
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gitBundledResources' defined in com.atlassian.stash.internal.scm.git.GitWiring: Invocation of init method failed; nested exception is java.io.IOException: Mount point not found
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1630)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:867)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:543)
at javax.servlet.GenericServlet.init(GenericServlet.java:158)
at java.lang.Thread.run(Thread.java:748)
... 17 frames trimmed
Caused by: java.io.IOException: Mount point not found
at sun.nio.fs.LinuxFileStore.findMountEntry(LinuxFileStore.java:91)
at sun.nio.fs.UnixFileStore.<init>(UnixFileStore.java:65)
at sun.nio.fs.LinuxFileStore.<init>(LinuxFileStore.java:44)
at sun.nio.fs.LinuxFileSystemProvider.getFileStore(LinuxFileSystemProvider.java:51)
at sun.nio.fs.LinuxFileSystemProvider.getFileStore(LinuxFileSystemProvider.java:39)
at sun.nio.fs.UnixFileSystemProvider.getFileStore(UnixFileSystemProvider.java:368)
at java.nio.file.Files.getFileStore(Files.java:1461)
at com.atlassian.stash.internal.scm.git.BundledResources.isPosixFilesystem(BundledResources.java:103)
at com.atlassian.stash.internal.scm.git.BundledResources.installScript(BundledResources.java:89)
at com.atlassian.stash.internal.scm.git.BundledResources.unpack(BundledResources.java:36)
... 5 common frames omitted
2018-09-17 09:38:12,822 WARN [http-nio-7990-exec-2] c.a.j.s.w.f.BypassableDelegatingFilterProxy Bypassing [hazelcastFilter]; no Spring WebApplicationContext is available
Mesut Yilmazyildirim
September 17, 2018
I think the user running Bitbucket does NOT have the proper permission in the BITBUCKET_HOME (the data directory). Can you please double check if you have the proper permission on this structure?
Nadica Gaber
Hi Mesut,
I've checked and the permissions look proper to me.
