Bitbucket Create/Delete branch based on Jira workflow
Ramya Yarru September 24, 2021 edited
Hello Team,
Can we Create/Delete branch in bitbucket based on Jira workflow?
Please advise.
Max Lim _Adaptavist_
November 27, 2021
Yes, you certainly can. You would need ScriptRunner in your Jira instance.
There are two ways to do it. Basically you make a POST call using the following Rest API to create a branch in a workflow post function from Jira to BitBucket:
/rest/branch-utils/1.0/projects/{projectKey}/repos/{repositorySlug}/branches
With App links, without need to pass username and password
1. Setup the app links as mentioned in this documentation.
2. Following snippet works as I have tested:
import com.atlassian.applinks.api.ApplicationLinkResponseHandler
import com.atlassian.applinks.api.ApplicationLinkService
import com.atlassian.applinks.api.application.bitbucket.BitbucketApplicationType
import com.atlassian.sal.api.component.ComponentLocator
import groovy.json.JsonSlurper
import com.atlassian.sal.api.net.Request
import com.atlassian.sal.api.net.Response
import com.atlassian.sal.api.net.ResponseException
import com.atlassian.sal.api.net.ResponseHandler
import groovy.json.JsonBuilder
def appLinkService = ComponentLocator.getComponent(ApplicationLinkService)
def appLink = appLinkService.getPrimaryApplicationLink(BitbucketApplicationType)
def applicationLinkRequestFactory = appLink.createAuthenticatedRequestFactory()
Map body = [
startPoint: "refs/heads/master",
def request = applicationLinkRequestFactory
.createRequest(Request.MethodType.POST, "/rest/branch-utils/1.0/projects/JP/repos/just-repository/branches")
.addHeader("Content-Type", "application/json")
.setRequestBody(new JsonBuilder(body).toString())
.execute(new ApplicationLinkResponseHandler<Map>() {
@Override
Map credentialsRequired(Response response) throws ResponseException {
return null
@Override
Map handle(Response response) throws ResponseException {
new JsonSlurper().parseText(response.getResponseBodyAsString()) as Map
With username and password
You can use this sample script from our library as reference to make the same POST call:
import groovy.json.JsonOutput
import groovyx.net.http.ContentType
import groovyx.net.http.HttpResponseDecorator
import groovyx.net.http.RESTClient
final externalUrl = "http://<BitBucket_Base_URL>/"
def body = [
def postResponse = post(externalUrl, "/rest/branch-utils/1.0/projects/JP/repos/just-repository/branches", new JsonBuilder(body).toString())
def post(def hostUrl, def endpointAndQuery, def bodyJson) {
def client = new RESTClient(hostUrl)
client.setHeaders([
'Accept' : ContentType.JSON,
'Authorization': "Basic ${'xxxx:xxxxxxxx'.bytes.encodeBase64()}"
client.handler.success = { HttpResponseDecorator response, json ->
json
client.handler.failure = { HttpResponseDecorator response ->
// Failure can be handled here
log.error response.entity.content.text
client.post(
path: endpointAndQuery,
contentType: ContentType.JSON,
body: bodyJson
Please note that this will hardcode a username and password in your script.
Deleting a branch is just similar using a DELETE call on the same REST API.
I hope this helps!
Ramya Yarru November 29, 2021
Thank you so much @Max Lim _Adaptavist_
Max Lim -Adaptavist-
November 27, 2021 edited
(deleted duplicated answer.)
Robert Giddings [Adaptavist]
November 26, 2021
@Ramya Yarru ,
Thank you for your question.
Please can I confirm if you have ScriptRunner for Jira or ScriptRunner for Bitbucket?
Robert Giddings,
Product Manager, ScriptRunner for Bitbucket
Ramya Yarru November 26, 2021
Hello @Robert Giddings [Adaptavist]
yes, i do have have scriptrunner for bitbucket and jira.
Thanks and Regards
Ramya
