I'm using Bitbucket cloud, and I want to more issue filter than standard "All", "Open", "My issues", "Watching".
As example: I want "my open issues", currently, I need to go to "Advanced search", specify something like:
Status is not closed & Assignee is myself
It return correctly, I need a way I can store such filter with name "My open issues", so I can just click on this shortcut I get what I need directly.
Hi Ashraf,
I've had the same issue and I'm using browser favorites as a workaround.
You can define your own view, by using the parameters in the URL.
If you want to have "Status is not closed & Assignee is myself"
You can use the URL: <your project>//issues?responsible=<yourname>&status=!closed
It works for basic filters but not so well if you need more fancy logical operators :-)
Best,
Mirko
Hi Ashraf, currently it's not possible to create new filters in Bitbucket Cloud but there's already a feature request that you can find at Custom filters.
For the future, if you have an idea about something you'd like to see in Bitbucket you can check our public Issue tracker to see if it has already been proposed, or submit your own by clicking Create Issue :)
Hope this helps!
Ana
Thanks for the reply & advice.
The original issue is opened year 2009, it seems it is not coming soon.
Any update on this change request?
Can we expect release of this feature in the near future?
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
