Bitbucket DB configuration issue
Brian Parks November 30, 2017 edited
Hi - trying to go through the migration process for BB server, and am stuck in a loop configuring SQL Server 2014. Here is the error dump:
Bitbucket could not be migrated to the new database. Some data may have already been written to the new database leaving it in an inconsistent state. You will need to empty or recreate the new database before trying again.
	com.atlassian.stash.internal.maintenance.migration.DatabaseMigrationTask.convertToMigrationException(DatabaseMigrationTask.java:86)
	com.atlassian.stash.internal.maintenance.migration.DatabaseMigrationTask.run(DatabaseMigrationTask.java:51)
	com.atlassian.stash.internal.maintenance.DefaultMaintenanceTaskMonitor.run(DefaultMaintenanceTaskMonitor.java:212)
Failed to execute change: Deletes data from an existing table; nested exception is liquibase.exception.DatabaseException: Invalid object name 'db_owner.sta_permission_type'. [Failed SQL: DELETE FROM [db_owner].[sta_permission_type]]
	com.atlassian.stash.internal.backup.liquibase.DefaultLiquibaseDao.applyChange(DefaultLiquibaseDao.java:352)
	com.atlassian.stash.internal.backup.liquibase.DefaultLiquibaseDao.deleteAllRows(DefaultLiquibaseDao.java:171)
	com.atlassian.stash.internal.backup.liquibase.DatabaseUpdater.onChangesetContent(DatabaseUpdater.java:57)
	liquibase.executor.jvm.JdbcExecutor$ExecuteStatementCallback.doInStatement(JdbcExecutor.java:309)
	liquibase.executor.jvm.JdbcExecutor.execute(JdbcExecutor.java:55)
	liquibase.executor.jvm.JdbcExecutor.execute(JdbcExecutor.java:113)
	com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:217)
	com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1655)
	com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:885)
Nevermind! I found the answer.
Designer TSIC
May 1, 2018
Can you elaborate? I have the same error.
Dawn Reed
May 1, 2018
Hi, we're no longer using BB. I wasn't sure how to remove my question. Good luck to you!
Deleted user July 17, 2018 edited
Deleted
