Bitbucket DC with Network requires Forward/Outbound Proxy Proxy link to Jira Software App Link Issue
limboonchia
September 8, 2024 edited
I am using Bitbucket 8.19 and Jira Software. I want to setup application link for Bitbucket DC that is running under network which requires forward/outbound proxy in order to access the internet including Jira Cloud. (i.e., all web request must route through the proxy).
I have tried to setup bitbucket DC and application link based on documentations. So far I can only setup connection from Bitbucket to Jira, but Jira is not able to reach the Bitbucket due to my outbound proxy. Any idea on how to link them up in both way ?
Jira App Link is having error
Bitbucket App Link Status
Bitbucket to Jira Status.png confluence.atlassian.com
https://confluence.atlassian.com/bitbucketserver0819/link-bitbucket-with-jira-1416826452.html
https://confluence.atlassian.com/bitbucketserverkb/how-to-configure-an-outbound-http-and-https-proxy-for-bitbucket-server-779171680.html
Robert Wen_Cprime_
May 23, 2025 edited
hello @limboonchia
You have to set up an application tunnel between Jira Cloud and Bitbucket DC.  The following docs may help.
https://support.atlassian.com/organization-administration/docs/what-are-application-tunnels/
Note that when you set up the application tunnel, you have to set up the outbound proxy as user environment variables, as outlined by this article.
https://support.atlassian.com/jira/kb/atlassian-application-tunnels-plugin-doesnt-work-via-outbound-proxy/
