I am using jenkins for CI stuff. I have bitbucket server installed and want to checkout the git URL (http/https) using jenkins job. I have installed Git client plugin and git plugin jenkins, versions are as follow,
Git client plugin =2.4.6
Git plugin = 3.3.2
When I provide the URL in job I get following error,
Same error when I error when I run the job.
> F:\app\Git\bin\git.exe fetch --tags --progress https://localhost:9090/scm/stcplay/mavensample.git +refs/heads/*:refs/remotes/origin/*
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Command "F:\app\Git\bin\git.exe fetch --tags --progress https://localhost:9090/scm/stcplay/mavensample.git +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: fatal: unable to access 'https://localhost:9090/scm/stcplay/mavensample.git/': The requested URL returned error: 403
Amazingly, when I do git clone invoking windows command prompt in jenkins it works perfectly.
Anyone faced the same issue earlier ?
I solved this issue.
The problem was with Jenkins proxy settings. It was blicking Bitbucket to connect with Git plugin and hence the error was there.
I need to mention Bitbucket hostname in the non-proxy host section under manage-jenkins-->manage plugins ---> Advance settings --> non-proxy hosts.
And then it will allow Bitbucket host to communicate with Git plugin and you were able to checkout code successfully.
cheers,
Shreedhar dhanawade
Worked for me too. Thanks !
Can someone provide some details here.
I have hosted jenkins on a linux machine.
I am able to clone the repository but in jenkins, the same git clone command is giving issues.
Failed to connect to repository : Command "git ls-remote -h https://anugrah_deloitte@bitbucket.org/nvs-ssc/training.git HEAD" returned status code 128:
stdout:
stderr: fatal: unable to access 'https://anugrah_deloitte@bitbucket.org/nvs-ssc/training.git/': Could not resolve host: bitbucket.org; Unknown error
Could you provide me what details did you provide in the proxy, since I have not provided any proxy details under HTTP Proxy Configuration under Advance settings
Anugrah
@anugrah_deloitte I have the same issue, could you please provide the way that how did you solve the issue
I have the same issue also, could you please provide the way that how did you solve the issue
I need help please
For me, git was not installed on the machine that was hosting Jenkins
This stack overflow helped me realize: https://stackoverflow.com/a/49823767/4375369
