×Hello,
We have Bitbucket and Jira instances which are managed by two different teams. When It comes to linking these two applications we need user account which will have admin rights on both instances.
I wanted check that, if we give a admin rights to account then establish link and them remove the admin rights from account in one of the instance, will this still work ? will this still keep linking?
Hi Shreedhar!
You didn't specify which platform are you using, I assumed you're in Cloud.
We've tested this for the Cloud platform and the integration does still work even when we remove the admin permissions from both Bitbucket and Jira. If you're using Server please let us know so we can test this as well.
Kind regards :)
Ana
