Bitbucket Merge Check script runner
Thejeswara Reddy R February 22, 2019
Hello All,
Here I have the code below which is not working properly.
import com.atlassian.bitbucket.pull.PullRequestParticipantStatus
import com.atlassian.bitbucket.scm.pull.MergeRequest
def mergeRequest = mergeRequest as MergeRequest
if (mergeRequest.pullRequest.reviewers.any { it.status == PullRequestParticipantStatus.NEEDS_WORK }) {
mergeRequest.veto("Please consult the reviewer.", "The merge is blocked by at least one reviewer.")
Kindly Help me ASAP!
Thanks in advance!
Julius Davies [bit-booster.com]
February 22, 2019
What version of Bitbucket are you on?   I don't think mergeRequest.veto() works on Bitbucket 6.
If you just want to block "Needs Work" pull-requests from merging, our Control Freak plugin provides that with just a few clicks:
Thejeswara Reddy R March 4, 2019
Thanks for the response!
Ana Retamal
February 22, 2019
Hi Thejeswara, ee need more context to be able to help you:
  • Where is this code from?
  • What should it do? What result are you getting?
  • Which tools are you using?
Please give us a better description of your situation or environment, otherwise we have no idea to know what's going on.
Ana
This script is about checking and blocking users until they wil get approval to merge the code on bitbucket branches.
It will be helpful if you forward this ticket to groovy script expert.
Thejes
Ana Retamal
March 5, 2019
Hi Thejes,
I'm afraid I won't be able to do that, as plugins are from third-party vendors. What you can do is to try to find the plugin vendor in our Marketplace section in Community, find them in the Marketplace and contact them directly, or let us know which plugin it is to see if someone with knowledge about it could help you.
Ana.
