Bitbucket Pipelines fails after seconds randomly
hanan rokach July 24, 2018
I'm running bitbucket pipeline to run some tests build docker image and shipping it to my server. The pipeline is failing randomly on some steps without any error.
The picture below is the same pipeline (in the last one I tried to disable some steps to see if it fixes this bug or doesn't - but not). This is randomly happen, when I press 'rerun' it sometimes fail on the build process or other step in my YAML file.
I'm using docker and mysql services (mysql for running some tests against DB, docker to build my image at the end and shipping it)
Please help me, my production server is depend on Bitbucket pipelines and it will be very disappoint if we'll need to move to other service..
Thanks a lot!
davina
August 13, 2018
Hi @Hanan Rokach
Are you still experiencing this issue?
Perhaps check the `docker` tab and see if the logs reveal anything. It could potentially be OOMing.
