×Hi, I have currently setup pipelines in a repository like some times before. I have a pipelines configuration with several commands. But I have the problem, that some commands are completely ignored by pipelines and not executed.
Here is my pipelines config:
image: sumafu/build_tools:1.1.0
pipelines:
custom:
build-app:
- step:
caches:
- node
script:
- npm --version
- node --version
- npm install
- npm run build:prod
artifacts:
- dist/**
- node_modules/**
- step:
script:
- cd dist/
- chmod +x assets/xmrig
- npm install
- cd ..
- npm run electron:package:mac
artifacts:
- release-builds/**
- step:
script:
- zip -r releases.zip release-builds
- curl -X POST "https://${BB_AUTH_STRING}@api.bitbucket.org/2.0/repositories/${BITBUCKET_REPO_OWNER}/${BITBUCKET_REPO_SLUG}/downloads" --form files=@"releases.zip"
No command from the second step is executed. First of all, the first and second steps were a single step, but the commands from cd dist/ were not executed. However, the second step is displayed as successful and therefore the last step fails, because then of course the artifacts of the second step are missing.
