Hi folks,
Is there an existing plugin for Bitbucket that would allow me to add a custom field to projects that pulls from a database using a SQL query?
I really like nFeed in Jira and also saw Deiser Profields.
Thank you ahead of time for suggestions :)
Hi!
sounds needful, it will be awesome to know the use case.
Gonchik Tsymzhitov
Thank you for taking interest @Gonchik Tsymzhitov
Our company has a database with all the business applications tagged by an asset ID.
That DB contains records for all incidents, changes, servers and other items all related to the business applications by its asset ID.
We would like the ability to tag a Bitbucket project to an asset ID retrieved from the above DB. This way when we produce reports, we can pull commits, number of repositories, etc. from Bitbucket for a particular asset.
Thank you again for your response :)
