Bitbucket Server Init Script - Status Problems
Derek Sheeman
August 7, 2017 edited
I have taken the init.d script documented here
https://confluence.atlassian.com/bitbucketserver/running-bitbucket-server-as-a-linux-service-776640157.html
And set it up to run my bitbucket application.  It stops and starts without any troubles, but the status command always throws an error:
[ec2-user@atl-bitbucket ~]$ sudo service atlbitbucket status
/etc/init.d/atlbitbucket: line 116: status_of_proc: command not found
After a little digging I went and verified rhel-lsb was installed and is at version 4.0.
I did also verify that the PIDFILE is being created in the defined location.
The application is running on an AWS linux instance.
I have placed my current version of the init script below, if anyone has experienced this problem before or sees a glaring error in the status segment that I'm missing, please help.
#! /bin/sh
### BEGIN INIT INFO
# Provides: bitbucket
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Initscript for Atlassian Bitbucket Server
# Description: Automatically start Atlassian Bitbucket Server when the system starts up.
# Provide commands for manually starting and stopping Bitbucket Server.
### END INIT INFO
# Adapt the following lines to your configuration
# RUNUSER: The user to run Bitbucket Server as.
RUNUSER=atlbitbucket
# BITBUCKET_INSTALLDIR: The path to the Bitbucket Server installation directory
BITBUCKET_INSTALLDIR="/opt/atlassian/current"
# BITBUCKET_HOME: Path to the Bitbucket home directory
BITBUCKET_HOME="/opt/atlassian/home"
# PATH should only include /usr/* if it runs after the mountnfs.sh script
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC="Atlassian Bitbucket Server"
NAME=atlbitbucket
#PIDFILE=$BITBUCKET_INSTALLDIR/work/catalina.pid
PIDFILE=$BITBUCKET_HOME/log/bitbucket.pid
SCRIPTNAME=/etc/init.d/$NAME
#Set Umask
umask 0027
# Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
# Define LSB log_* functions.
# To be replaced by LSB functions
# Defined here for distributions that don't define
# log_daemon_msg
log_daemon_msg () {
echo $@
# log_end_msg
log_end_msg () {
retval=$1
if [ $retval -eq 0 ]; then
echo "."
else
echo " failed!"
fi
return $retval
# Depend on lsb-base (>= 3.0-6) to ensure that this file is present.
. /lib/lsb/init-functions
run_with_home() {
if [ "$RUNUSER" != "$USER" ]; then
su - "$RUNUSER" -c "export BITBUCKET_HOME=${BITBUCKET_HOME};${BITBUCKET_INSTALLDIR}/bin/$1"
else
fi
# Function that starts the daemon/service
do_start()
run_with_home start-bitbucket.sh
# Function that stops the daemon/service
do_stop()
if [ -e $PIDFILE ]; then
run_with_home stop-bitbucket.sh
else
log_failure_msg "$NAME is not running."
fi
case "$1" in
start)
[ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
do_start
case "$?" in
0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
esac
stop)
[ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
do_stop
case "$?" in
esac
status)
if [ ! -e "$PIDFILE" ]; then
return 1
fi
status_of_proc -p "$PIDFILE" "" $NAME && exit 0 || exit $?
restart|force-reload)
# If the "reload" option is implemented then remove the
# 'force-reload' alias
log_daemon_msg "Restarting $DESC" "$NAME"
do_stop
case "$?" in
0|1)
do_start
case "$?" in
0) log_end_msg 0 ;;
1) log_end_msg 1 ;; # Old process is still running
*) log_end_msg 1 ;; # Failed to start
esac
# Failed to stop
log_end_msg 1
esac
echo "Usage: $SCRIPTNAME {start|stop|status|restart|force-reload}" >&2
exit 3
esac
