Bitbucket Server not starting
Philipp Mager
October 25, 2016
I changed the keystore file of the Tomcat, and had a couple of errors afterwards. After I fixed them (https://confluence.atlassian.com/bitbucketserverkb/bitbucket-server-does-not-start-could-not-acquire-change-log-lock-779171307.html) I tried starting it again. Now it does not print any error in the log files, but keeps hanging on "Initializing Spring context". What should I do next?
Bitbucket Version 4.6.0
Vishnu Reddy K
HI Phillipp,
  Can you please try to clear the plugin cache and try restarting again.I think on of you core plugins frame work are corropt.
  1. Shut Bitbucket Server down.
  2. Backup and remove the following directories. The core plugins will be rebuilt when Bitbucket Server starts again.
    1. $BITBUCKET_HOME/plugins/.bundled-plugins/
    2. $BITBUCKET_HOME/plugins/.osgi-cache/
  3. Restart Bitbucket Server.
Thanks & Regards
Vishnu
Philipp Mager
October 25, 2016
Just made a fresh restart.
atlassian-bitbucket.log:
... (Older timestamps)
2016-10-25 18:35:05,486 INFO [spring-startup] c.a.s.i.server.BuildInfoLogger Starting Bitbucket 4.6.0 (e31c644 built on Mon May 09 06:21:50 CEST 2016)
2016-10-25 18:35:05,486 INFO [spring-startup] c.a.s.i.server.BuildInfoLogger JVM: Oracle Corporation Java HotSpot(TM) 64-Bit Server VM 1.8.0_74-b02
2016-10-25 18:35:05,502 INFO [spring-startup] c.a.s.internal.home.HomeLockAcquirer Successfully acquired lock on home directory C:\Atlassian\ApplicationData\Bitbucket
2016-10-25 18:35:07,814 WARN [spring-startup] c.z.hikari.util.DriverDataSource Registered driver with driverClassName=oracle.jdbc.driver.OracleDriver was not found, trying direct instantiation.
catalina.2016-10-25.log:
25-Oct-2016 18:34:49.285 WARNING [main] org.apache.catalina.startup.SetAllPropertiesRule.begin [SetAllPropertiesRule]{Server/Service/Connector} Setting property 'maxSpareThreads' to '75' did not find a matching property.
25-Oct-2016 18:34:49.332 WARNING [main] org.apache.tomcat.util.digester.SetPropertiesRule.begin [SetPropertiesRule]{Server/Service/Engine/Host} Setting property 'xmlValidation' to 'false' did not find a matching property.
25-Oct-2016 18:34:49.332 WARNING [main] org.apache.tomcat.util.digester.SetPropertiesRule.begin [SetPropertiesRule]{Server/Service/Engine/Host} Setting property 'xmlNamespaceAware' to 'false' did not find a matching property.
25-Oct-2016 18:34:49.363 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Atlassian\Bitbucket\4.6.0\lib\native;C:\\Atlassian\\ApplicationData\\Bitbucket\lib\native
25-Oct-2016 18:34:49.628 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-80"]
25-Oct-2016 18:34:49.722 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
25-Oct-2016 18:34:49.738 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-443"]
25-Oct-2016 18:34:50.175 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
25-Oct-2016 18:34:50.175 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1530 ms
25-Oct-2016 18:34:50.207 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
25-Oct-2016 18:34:50.207 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.32
25-Oct-2016 18:34:58.050 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
25-Oct-2016 18:34:59.768 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-80"]
25-Oct-2016 18:34:59.909 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-443"]
25-Oct-2016 18:34:59.909 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 9737 ms
Jeff Thomas
October 25, 2016
Do you see anything in the following two log files to indicate why it's not starting?
$BITBUCKET_HOME/log/atlassian-bitbucket.log
<Bitbucket Server installation directory>/logs/catalina.out
