Bitbucket cloud webhooks for create pull request doest not trigger Jenkins pipeline build
Shweta Thakur
November 12, 2017
We have a requirement to trigger a Jenkins Pipeline build when a pull request is created.
Below are the configurations that we have for Bitbucket :
1: Added a webhook with URL with active state
http://<jenkinshost>:<jenkinsport>/bitbucket-scmsource-hook/notify
2: Selected radio button Choose from a full list of triggers
3: Selected Pull Request event, Pull Request Created
On the Jenkins side we have below configurations:
1: Poll SCM set to true with a longer interval
2: Discover Branches Strategy: "All Branches"
3: Bitbucket Enpoints > Bitbucket Cloud > Manage Hooks set to checked
Logs on Jenkins server:
com.cloudbees.jenkins.plugins.bitbucket.hooks.BitbucketSCMSourcePushHookReceiver
X-Bitbucket-Type header not found. Bitbucket Cloud webhook incoming.
Finished processing com.cloudbees.jenkins.plugins.bitbucket.hooks.PullRequestHookProcessor$1 CREATED event from  ⇒ http://<JenkinsHost>:<jenkinsport>/bitbucket-scmsource-hook/notify with timestamp  Matched 0.
It seems it is not able to detect the changes as it always says Matched 0.
If we change the trigger from Pull request created to Repo push everything seems to work fine, only Pull request created does not work
Are we missing any specific setting on Bitbucket or Jenkins side?
Muddassir Farooq February 22, 2018
Please use the https://wiki.jenkins.io/display/JENKINS/Generic+Webhook+Trigger+Plugin . It will trigger the build when PR created and Updated. It also hold all the payload from bitbucket webhook.
Anirudh Menon
January 8, 2019 edited
Any updates on this one? I am using Jenkins v2.153. Is there a work around?
Muddassir Farooq February 21, 2018
any reply on this.
I m also facing the same.
Abhisek Tripathy September 14, 2018
M also facing the same.for a multibranch pipeline job.
