Bitbucket pipeline not triggered when pushing multiple tags.
Dmitrijs Pavlovs
July 24, 2020
Hello i am using lerna to publish tags to repository. It means i am pushing 16 tags at once. The issue is it doesn't trigger the pipeline. I tested with only 1 tag per push and it works otherwise. Github pipelines has the same issue. https://github.community/t/tag-creation-trigger-not-working-with-lerna-publish/17314
What is the reason behind the pipeline trigger breaking on multiple tags per publish ? Is there any workarounds ?
Yulong Ruan
September 23, 2022 edited
This seems still to be the limitation at the moment, we have a monorepo and we do multiple tags and releases at one time. But the pipeline didn't get triggered.
Pipelines running on multiple tags are necessary for a monorepo setup, if such constraint is needed for most common cases, probably it is also wise to provide user options to disable it.
Gabriel Labelle
November 9, 2021
Did you find a solution to this problem. We have the same issue. We use lerna that pushes multiple tags back into the branch but it doesn't trigger a pipeline.
