I have the defined multiple anchors and using them like below:
Example found here: https://confluence.atlassian.com/bitbucket/yaml-anchors-960154027.html
but I am getting:
There is an error in your bitbucket-pipelines.yml at [pipelines > branches > feature/* > 2 > step]. To be precise: This section should be a map (it is currently defined as a list).
What am I doing wrong ? So the idea is to run the steps in dev-env and common-env before the actual script ./sfdx.sh deploy
branches:
feature/*:
- step: *dev-env
- step: *common-env
- step:
- trigger: automatic
- script:
- ./sfdx.sh deploy
Hi @Jani Ruohomaa,
as the error indicates, the attributes of your step should not be list items. So try something like this:
branches:
feature/*:
- step: *dev-env
- step: *common-env
- step:
trigger: automatic
script:
- ./sfdx.sh deploy
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
