My pipeline is:
image: java:8
pipelines:
default:
- step:
caches:
- gradle
- android-sdk
script:
# Download and unzip android sdk
- wget --quiet --output-document=android-sdk.zip https://dl.google.com/android/repository/sdk-tools-linux-4333796.zip
- unzip -o -qq android-sdk.zip -d android-sdk
# Define Android Home and add PATHs
- export ANDROID_HOME="/opt/atlassian/pipelines/agent/build/android-sdk"
- export PATH="$ANDROID_HOME/tools:$ANDROID_HOME/tools/bin:$ANDROID_HOME/platform-tools:$PATH"
# Download packages.
- yes | sdkmanager "platform-tools"
- yes | sdkmanager "platforms;android-29"
- yes | sdkmanager "build-tools;29.0.2"
- yes | sdkmanager "extras;android;m2repository"
- yes | sdkmanager "extras;google;m2repository"
- yes | sdkmanager "extras;google;instantapps"
- yes | sdkmanager --licenses
# Build apk
- chmod a+x ./gradlew
- ./gradlew assembleDebug
branches:
develop:
- step:
caches:
- gradle
- android-sdk
script:
# Build apk
artifacts:
- app/build/outputs/apk/debug/*.apk
definitions:
caches:
android-sdk: android-sdk
I want to move
to script build.sh, and do like this:
image: java:8
pipelines:
default:
- step:
caches:
- gradle
- android-sdk
script:
- ./build.sh
# Build apk
branches:
develop:
- step:
caches:
- gradle
- android-sdk
script:
- ./build.sh
# Build apk
artifacts:
definitions:
caches:
But I have errors:
+ ./build.sh
./build.sh: line 4: -: command not found./build.sh: line 5: -: command not found
./build.sh: line 8: -: command not found
Any ideas?
Hi @SmsParser
Bitbucket uses a special YAML file format to represent the pipeline tasks configuration. It does not work like a shell script although it has some similarities. The external file you are trying to call as a script should be in shell format. There are multiple shell types out there like csh, sh, bash etc.
This is an example of how your script could look like:
#!/bin/bash
You could use any type of complex bash script structures inside this file. It is not treated as an extension of a pipeline configuration, but as a terminal script that needs to be run.
I hope that clarifies the issue.
