I used the AWS deploy S3 pipeline as a template. So the ci_scripts are pretty much the same.
My build step is currently failing at a script called git-commit.sh
+ ./ci-scripts/git-commit.sh
[master 7dbc791] Update files for new version '0.1.0' [skip ci]
1 file changed, 2 insertions(+), 1 deletion(-)
Warning: Permanently added the RSA host key for IP address '18.205.93.2' to the list of known hosts.
Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
code for this:
git add .
git commit -m "Update files for new version '${tag}' [skip ci]"
GIT_SSH_COMMAND="ssh -i ~/.ssh/id_rsa -F /dev/null" git push origin ${BITBUCKET_BRANCH}
I have followed the steps here: https://confluence.atlassian.com/bitbucket/push-back-to-your-repository-962352710.html in the
part
@gdmacmillan , you probably need to configure the SSH keys so that they are stored in the proper location. There are two ways of configuring SSH keys in Pipelines:
SSH Key pair managed with variables. https://confluence.atlassian.com/bitbucket/push-back-to-your-repository-962352710.html#Pushbacktoyourrepository-SSHKeypairmanagedwithvariables
The example you are using uses the second option, moving the SSH key from a environement variable to the proper location as shown here: https://bitbucket.org/atlassian/aws-s3-deploy/src/master/ci-scripts/git-setup.sh
I recommend using the first option when possible as it would be easier to configure.
I think the ssh key may not be in ~/.ssh/ but could be at /opt/atlassian/pipelines/agent/ssh
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
