Is it possible to push build status notifications via SSH to Stash? Unfortunately API access requires a user login and that affects the license.
Maybe you could try to setup SSH keys between the servers to see if it works without a password. Another possibility would be to create an script with User and Password. To do it, you could use "Expect". However, you may need to install it. Below, you can see an example on how you could do it using "Expect"
#!/usr/bin/expect
spawn /path_to_your_script
expect "password:"
send — "your_password\r"
send -- "\r"
expect elf
Good Luck :)
Hi!
Seems like the new Bamboo release has a new notification type and you don't need a user anymore. This should solve your problem.
https://confluence.atlassian.com/display/BAMBOO/Bamboo+5.6+release+notes
