Has anyone managed to integrate CAS SSO with Bamboo?
Confluence and JIRA are supported https://wiki.jasig.org/display/CASC/Configuring+Jira+with+JASIG+CAS+Client+for+Java+3.1
For Stash I even found an addon but no documentation for Bamboo.
Should I use the documentation for Java in web.xml? https://wiki.jasig.org/display/CASC/Configuring+the+Jasig+CAS+Client+for+Java+in+the+web.xml
That's what I tried but there is only an existing implementation for Confluence and Jira. Not for Bamboo.
So I was wondering if I have to write custom code or if there is an easier solution
