Can I access a deployment environment variable within a shell script?
Ahmad Mayahi
January 7, 2019 edited
I have a file named `deploy.sh` in the repository and I want to access some pipeline environment variables within the script.
I use the following command in my `bitbucket-pipelines.yml` file:
ssh user@host 'bash -s' < 'deploy.sh'
The `deploy.sh` contains some environment variables that are defined in the pipeline:
echo $TEST_FOLDER_PATH
The `TEST_FOLDER_PATH` defined in the `Test` environment as follows:Screenshot 2019-01-07 at 13.37.13.png
So, the question is, how do I read the `TEST_FOLDER_PATH` within the `deploy.sh` file?
Kenny MacLeod
January 7, 2019
Shell scripts executed from bitbucket-pipelines.yml can access such environment variables just fine, but they have to be executed as part of the step, e.g.
   script:
- deploy.sh
From your question, it looks like you're trying to execute your script on a remote host, triggered by a Pipeline. The remote host won't have any knowledge of the environment variables set up by pipelines, so you'd need to pass those along as arguments to the remote script invocation some how. Hard to be more specific without knowing what the script does, what the env vars are, etc.
amurashkin November 3, 2019
And what if we executing script remotely using atlassian/ssh-run ?
Attila Berczik November 3, 2021
Were you able to solve this problem?
Now I am trying to do the same thing.
Could you help me?
amurashkin November 4, 2021
Need to use something like
ssh user@host 'bash -s' < "deploy.sh $TEST_FOLDER_PATH"
And process it as  parameter in your  deploy.sh
