Can I add arbitrary attributes to Projects and Repositories
Barclays Vendor Management
We want to log some internal data attributes e.g. project codes or application classifications against projects and repositories.  Is there a way we can do this in a way that these would be accessible to users through the web UI but also via REST?
Ulrich Kuhnhardt _IzymesDev_
December 18, 2015
We usually use Active Objects to store data in plugins. It is also possible to store simple key-value data in the plugin settings service > example.
Your best bet is to write a small add-on that provides the REST endpoints, data storage and web-fragments.
Best, Ulrich [Izymes]
