HI Team,
How can i able to add comment to my jira task using gulp,
i have found below plugin in that they have mentioned we can add comment to jira task using this plugin
plugin - https://github.com/Pharb/gulp-jira-todo#getting-started
And i get some reference from here - https://developer.atlassian.com/server/jira/platform/jira-rest-api-example-add-comment-8946422/
How to do this...i want to add comment to my jira task using gulp
Hey @Kumaresan_Subramani ,
Thanks for including your steps and curl call here to help diagnose the issue you're seeing!
I see that you're trying to submit a comment to Jira Cloud. Earlier this year, we forced a change from passwords to API tokens in REST API calls. Based on the error you're seeing, I believe you may be passing your Jira password (rather than an API token) in your request. Switching to an API token should resolve this error.
Details about how to use these with Atlassian Cloud are listed here. In short, you generate a new token from id.atlassian.com and use that in place of a password. The advantage to this is that you can have multiple tokens on your account (one per application) and they can be easily revoked!
Daniel
HI @Daniel Eads ,
Thank You so much for your reply,
I have created `api token` and now i am facing below error while using below curl command
C:\Users\J**a>curl -u kumaresan.subramani:c************1 -X POST --data '{"body": "comment."}' -H "Content-type: application/json" https://****.atlassian.net/rest/api/2/issue/****/comment
ERROR Message
curl: (3) [globbing] unmatched close brace/bracket in column 9
{"errorMessages":["Unexpected character (''' (code 39)): expected a valid value (number, String, array, object, 'true', 'false' or 'null')\n at [Source: org.apache.catalina.connector.CoyoteInputStream@38a28add; line: 1, column: 2]"]}
C:\Users\JeevakanthPalaniappa>
Then i discovered what i am missing from below issue:
So i have tried my curl command like below but this command also throws an error:
C:\Users\J**a>curl -u kumaresan.subramani:c************1 -X POST --data "{\"body\": \"comment.\"}" -H "Content-type: application/json" https://****.atlassian.net/rest/api/2/issue/****/comment
ERROR Message
{"errorMessages":["Issue does not exist or you do not have permission to see it."],"errors":{}}
But task is in open stage and not get closed
I have used below curl and referred from this documentation:
C:\Users\****>curl -D- -u kumaresan.subramani:**** -X POST --data { "body": "This is a comment regarding the quality of the response." } -H "Content-Type: application/json" https://****.atlassian.net/rest/api/2/issue/****/comment
ERROR Message
curl: (6) Could not resolve host: body
curl: (6) Could not resolve host: This is a comment regarding the quality of the response
curl: (3) [globbing] unmatched close brace/bracket in column 1
HTTP/1.1 400
Server: AtlassianProxy/1.15.8.1
Cache-Control: no-cache, no-store, no-transform
Content-Type: application/json;charset=UTF-8
Strict-Transport-Security: max-age=315360000; includeSubDomains; preload
Date: Sat, 08 Feb 2020 08:41:20 GMT
ATL-TraceId: e4edd21f9421b202
X-AREQUESTID: 98a45289-1e24-4411-9370-a917285fa323
X-XSS-Protection: 1; mode=block
Transfer-Encoding: chunked
Timing-Allow-Origin: *
X-Content-Type-Options: nosniff
Connection: close
Set-Cookie: atlassian.xsrf.token=B7SF-5IF6-KCX8-F16W_6fbd6434c26778501fa34b7fab8c1adb4d67a8c2_lout; Path=/; Secure {"errorMessages":["Unexpected end-of-input: expected close marker for OBJECT (from [Source: org.apache.catalina.connector.CoyoteInputStream@7c8561d9; line: 1, column: 0])\n at [Source: org.apache.catalina.connector.CoyoteInputStream@7c8561d9; line: 1, column: 3]"]}
HI Team,
Kindly please update on this
kumaresan S
Through jenkins pipeline
one more way to achieve my requirement through Jenkins stage using below plugin
plugin - https://github.com/jenkinsci/jira-steps-plugin
Reference - https://jenkinsci.github.io/jira-steps-plugin/
To Add Comment - https://jenkinsci.github.io/jira-steps-plugin/steps/comment/jira_add_comment/
I want to confirm which one is better and possible
Hi Team,
i came up with new way to achieve my requirement
Through Curl in gulp
is this get work, i found these while searching
If yes, please be little more details.
HI Guys,
kindly please provide solution for this.
i have tried below curl since i am facing new issue
curl -D- -u kumaresan.subramani:** -X POST --data "{\"body\": \"comment.\"}" -H "Content-Type: application/json" https://**.atlassian.net/rest/api/2/issue/***/comment
HTTP/1.1 404
Vary: Accept-Encoding
Date: Tue, 18 Feb 2020 12:56:28 GMT
ATL-TraceId: 6459289388132163
X-AREQUESTID: b340e20c-213f-42f5-a718-e7a17955d6b8
Connection: keep-alive
Set-Cookie: atlassian.xsrf.token=B7SF-5IF6-KCX8-F16W_a077ccd048f8990999231421db66ff93901a0952_lout; Path=/; Secure {"errorMessages":["Issue does not exist or you do not have permission to see it."],"errors":{}}
I have used my api token only
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
