Here's what my yaml file looks like, but it doesn't work. Just stays in progress, I stopped it after 15 min. There's only 1 html file to transfer as I'm just trying to get it to work.
pipelines:
branches:
master:
- step:
caches:
- docker
name: Deploy to Staging
deployment: staging
services:
- docker
script:
- pipe: atlassian/ftp-deploy:0.2.0
variables:
USER: 'XXXXXX'
PASSWORD: 'XXXXXX'
SERVER: 'IP_ADDRESS'
REMOTE_PATH: '/var/www/vhosts/funny.com/httpdocs/prod'
Hi @Kevin Campbell. It's hard to say what might be wrong without additional info. Can you try running the pipe with debug mode enabled by adding DEBUG: 'true' to the pipe variables? Let me know if any meaningful shows up in the pipe logs.
Hi Alexander,
It still just hangs and debug doesn't add any info. Here's a screenshot after 6 min
Weird. I'd also check if your server is reachable from pipelines. You might try to run the raw lftp command.
pipelines:
branches:
master:
- step:
deployment: staging
image: alpine:3.9
script:
- apk add --update --no-cache bash lftp
- lftp -u $USER,$PASSWORD -e "set ftp:ssl-allow no; mirror --delete-first -vvv -R ${LOCAL_PATH} ${REMOTE_PATH};quit" $SERVER
So I need to add
$USER
$PASSWORD
${LOCAL_PATH}
${REMOTE_PATH}
$SERVER
as values in quotes?
These are the parameters you would pass to the pipe, so you need to replace them with your own.
