Cant delete Project that has no Repositories
brian_goulter
I have a Project called "Untitled project".  The Project page says
"A new home for your brilliant idea
Now that you've got a project, let's bring in some repos and get cracking."
There are NO repos.
I click on "Project settings" and then click on "Delete project"  but the pop-up says
"You cannot delete this project because it still contains repositories. To delete the project you must first move or delete any repositories."
Any thoughts on what I am doing wrong?
3 votes
Brian Goulter
I think I have worked out what the problem is.   I found a repository created using Mercurial. BitBucket no longer supports Mercurial repositories. So the repository cannot be deleted (and isn't even listed if you go into the Projects listing).  As a consequence, the project itself cannot be deleted.
Dave Liao
November 17, 2020
Whoa, good sleuthing! I can escalate this to Atlassian Support to help delete your project - unless you already have an open support ticket with them?
Brian Goulter
Thanks Dave - that would be great (I will have to learn how to create a ticket!).  I have no need for the old mercurial repository. It will have nothing of value in it.  It would have been created when I first dabbled in using Bitbucket  (I have been using Mercurial - via TortoiseHg  for some time  - obviously I am revisiting BitBucket to try and conquer my fear of the unknown.)
Like Dave Liao likes this
Dave Liao
November 17, 2020
Escalated!
Like Brian Goulter likes this
Brian Goulter
Just fyi    the name of the repo that can be deleted  is bbs_82f755_hg
From my (failing) memory, the bbs  stood for Bridge Bidding Systems. I play bridge and was creating a database of various systems (what bids mean etc).   But I will have that info elsewhere.
Dave Liao
November 17, 2020
@brian_goulter  - that's a weird one.
Try associating a repo to your project, then un-associate that repo. Then try deleting the project again?
Brian Goulter
Hi Dave
Thanks for the answer (and as you were writing your answer, I think I found the cause of the problem).
I had already tried your suggestion (made a repo, removed it so that again there were no repo's listed).
But this is the sort of "try this ..." suggestion that us newbies need.
Dave Liao
November 17, 2020
Obviously a reply like mine shouldn't be the answer long-term. ;-p
Brian Goulter
From my experience,   I try a dozen different things.  Finally, something works,   but then I can't work out which of the things I did were necessary  (and did they have to be done in a certain order...).   It makes it hard to offer recommendations to others!
Like Deleted user likes this
