Checkout and merge into another git branch
TylerAvocat
I setup a manual step to merge the branch "master" into the branch "rc".
script:
    - git fetch
    - git checkout rc
    - git config
    - git rebase master
    - git push
I get "error: pathspec 'rc' did not match any file(s) known to git." but I am sure the branch is there.
I know that Pipeline only checkout the triggering branch at the beginning of a step: git clone --branch="master"
Could that prevent from accessing other branches ?
davina
October 9, 2018
Hi @TylerAvocat
You can configure your fetch by adding this to your configuration before the fetch command
- git config remote.origin.fetch "+refs/heads/*:refs/remotes/origin/*"
As a side note you can check what exists via
- git show-ref
 Hope this helps
Ilan Hazan July 31, 2019
The full commands to do the merge are:
git checkout master
git merge --no-ff --no-edit develop
git push
git push --tags
See full BitBucket's Pipeline script for merging branches
Like Felipe likes this
harsh-mrikal
October 4, 2024 edited
I'm encountering an error:
error: pathspec 'feature/example/auto-merge' did not match any file(s) known to git.
Below is my script:
- `git config --global user.email "example@example.com"`
- `git config --global user.name "example"`
- `git config remote.origin.fetch "+refs/heads/*:refs/remotes/origin/*"`
- `git checkout feature/example/auto-merge`
- `git merge origin/feature/example/auto-merge-stage --no-ff -m "Merged stage into dev2"`
- `git push origin feature/example/auto-merge`
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
