I am trying to clone a bitbucket repository and got the below error message.
I am doing it on a Windows machine.
I tried many different ways to see if it works.
1) Visual Studio Code: Same error, error screenshot below
2) Brackets: Same error, error screenshot below
3) Source Tree : Same error, error screenshot below
4) Git Hub: Same error, error screenshot below
However, when I tried the same repository on mac pro with Brackets, it worked fine.
Is it because of proxy or DNS or some thing?
I put so much effort and could not get rid of this, I really appreciate your suggestions or tips to fix this.
Thank you so much :)
Krishna
I had same error and below worked for me.
$ git config --global user.name "Emma Paris"
$ git config --global user.email "eparis@atlassian.com"
I set user name and password same as of my bit bucket account.
Since you are using windows, you might have to use different commands but key point here is to configure git account.
This is not related to the original question. If your DNS resolution is broken, then changing git config parameters will not resolve that.
That did solve the problem for me, too. It might be an issue with git.
@jredmond that did solve the problem too for git push error. it has the same error message like
fatal: unable to access 'https://bitbucket.org/xxx/xxx.git/': Could not resolve host: bitbucket.org
Yes, this does look like a DNS issue. Can you reach Bitbucket from a browser on that system?
Yes, James,
I could not even get any response from www.google.com.
Error: "Ping request could not find host www.google.com. Please check the name and try again."
Any trick or tip to get rid of this?
Thanks for your response.
Krishna
Hello James,
Which is my URL? Sorry, I am not sure.
The one in the URL area of the browser? I am able to access the below one from the same machine.
https://bitbucket.org/krishnabasvani/panxxxxxxrepo/src/master/
or copied from the clone option? but not this one.
https://krishnabasvani@bitbucket.org/krishnabasvani/panxxxxxrepo.git
Thank you!
Krishna
Both of those go to bitbucket.org, but the second one includes the username. That isn't necessary for browser access, as your user session is managed by the login process.
Check your internet Connection and DNS. if internet is working verify your company/router is not blocking the access to the domain
Hello Pavan,
I can access all the websites through browser and I think there is no problem with internet. I do not know how to check that if company is blocking access to a domain.
When I ping from command prompt, it does not allow pings to any website.
Thank you!
Krishna
Yes Pavan,
Looks like either firewall or antivirus.
Thank you!
Krishna
What if i got this same unable to resolve host error while pulling data into remote desktop through SSH? Would it be problem by local installed antivirus? because I don't have any antivirus on remote.
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
