Code review solution for Stash?
Daisuke Niwa
Hello there,
We heard Atlassian will not support Git in future release of FishEye. This means if you want to manage Git within Atlassian tools, you need to migrate to Git.
Our concern is code reivew feature which at the moment Crucible provides. Is there any substitutional feature for code review within Stash?
Please let us know.
Daisuke Niwa
3 votes
seb
June 5, 2012
Hi Daisuke,
Atlassian will absolutely be supporting Git in the future with FishEye. Crucible will continue to be available for formal code reviews from Git repositories.
In the future we will be removing FishEye's ability to serve Git repositories, but it will still support indexing as it currently does.
Seb
seb
June 5, 2012
Yes, we will be removing the ability to create an "internal repository"
Daisuke Niwa
Hello Seb,
Thank you for your quick response. Am I right in understanding that what you are going to remove from FishEye is the ability to create "internal repository"?
Appreciate your confirmation.
Daisuke Niwa
Daisuke Niwa
Thanks, understood the situation.
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
