Commit file using custom editor
Glib September 11, 2019 edited
I'm developing connect plugin for Bitbucket Cloud which adds a custom file viewer and editor.
Its pretty straightforward to add those 2 but I'm stuck now with committing the file once edited in custom editor as I'm not able to access resources outside editor iframe.
In the connect Json I'm adding editor module
"fileEditors": [{
"key": "custom-editor",
"name": {
"value": "Custom view"
"url": "/custom-editor.html?repo={repo_uuid}&cset={file_cset}&path={file_path}&name={file_name}",
"file_matches" : {
"extensions" : [ "custom-extension" ]
Is the any sort of event I can trigger when the editor content has changed in order to commit the file?
Glib
seanaty
September 11, 2019
Hi Glib,
Here is a example of the events that your app can emit and listen for. In this example there is a <textarea id=source> on the page.
You can use `editor.getSourceFRomHost` to get the file contents. and `editor.emit('change', 'new source')` to trigger a change.
AP.require(['editor'], function (editor) {
 $(function () {
   var $source = $('#source');
   editor.getSourceFromHost(function (source) {
     $source.val(source);
   var change = function () {
     editor.emit('change', $source.val());
   $source.change(change);
   $source.keyup(change);
   editor.addListener('reset', function (source) {
   editor.addListener('focus', function () {
     console.log('focus')
   editor.addListener('refresh', function () {
     console.log('refresh')
   editor.addListener('disable', function () {
     console.log('disable')
   editor.addListener('enabled', function () {
     console.log('enable')
   editor.emit('load');
Glib September 12, 2019
Hi @seanaty ,
Cant be more grateful for your help! That is exactly what I was looking for!
Glib
