We've got a Python-based app server running on a Linux image. We're trying to connect to a Linux container running SQL Server on port 1433.
We're using unixODBC and FreeTDS, and everything works when creating a local network (`docker network create --driver bridge --subnet 172.21.0.0/24 our_network.bridge`), then adding the containers to the network. Then we can access SQL Server's data source by name (`docker run -itd --network=our_network.bridge --name local-mssql microsoft/mssql`), local-mssql in this case.
We can `telnet 127.0.0.1 1433`, so the port is open. But using unixODBC command line tool isql (parameters: server name, username, password), this is the result:
+ isql -v sqlserver sa supersecret
[ISQL]ERROR: Could not SQLConnect
[S1000][unixODBC][FreeTDS][SQL Server]Unable to connect to data source
[01000][unixODBC][FreeTDS][SQL Server]Unknown host machine name.
Any idea how we can access to our database?
Hey @[deleted], I'm not super familiar with unixODBC, but I can talk about the general network set up.
When using Pipelines services, the processes running inside these containers all share a network interface with the main step execution container. This is why you can access everything via localhost / 127.0.0.1, and why there can be no port conflicts between services (can't run nginx and apache on port 80 for example).
As a common rule, each service must listen for connections from localhost/127.0.0.1, and the clients should connect to localhost.
Is it possible your command
is trying to connect to a remote host named 'sqlserver' and not `localhost` ?
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
