Connection bitbucket to Oracle data integrator
pankaj kumar tanwar February 20, 2018
Hi Team
I am trying to integrate ODI 12c to bitbucket and the detail requested by ODI are visible in my account has anyone tried this before
For example
ODI-12507: The Git Repository URL is not valid for the Git connection type [Git Basic]. The expected format is [git://<host>[:<port>]/<git-repository>].
I dont have port number i tried 22 /7990
Regards
Pankaj
Dan Benson January 4, 2019
I'm having the same issue.  Was this ever resolved?
jredmond
January 4, 2019
The same issue with "Git basic", or something else?
With SSL connection type I receive: ODI-12436: Unable to connect to Git remote repository with the information provided. invalid advertisement of <!DOCTYPE html><html lang="en"><head><meta charset="utf-8"><meta http-equiv="X-UA-Compatible" content="IE=edge"><title>Log in - Sparta Bitbucket</title><script>.
With SSH connection type I receive: ODI-12436: Unable to connect to Git remote repository with the information provided. Authentication failed due to invalid Private Key File.
I can use ssh/git from the command line fine.   It appears to be an ODI issue.
pankaj kumar tanwar January 6, 2019
Hi
Yes it was ODI issue with cloud based git. Newer version of ODI  12.2.1.3.0 works fine with cloud git
Apolodor April 5, 2020
what settings did you use?
thanks
jredmond
February 20, 2018
The git:// protocol is not currently supported by either Bitbucket Server or Bitbucket Cloud. Do you have any other options for repository type?
Hi James
Thanks for your input
Option i have to authenticate
1. HTTP Basics Authen
2. git basic
3. ssh auth
4. file auth
5. ssl auth
No sure of the repo type which you have asked
jredmond
February 20, 2018
Try ssh authentication.
Hi
I tried that as well it's also asking for port number
ODI-12507: The Git Repository URL is not valid for the Git connection type [SSH]. The expected format is [ssh://<username>@<host>[:<port>]/<disk-path-of-git-repo>].
ODI-12436: Unable to connect to Git remote repository with the information provided. ssh://ptanwar29@bitbucket.org:7990/<C:\Users\Ptanwar\odi>: Connection timed out: connect, Network issue or invalid Url.
jredmond
February 20, 2018
Bitbucket Cloud's ssh service is available on port 22, or you can also use altssh.bitbucket.org:443 .
Sorry to be asking again
the connection string in this case will be
ssh://ptanwar29@bitbucket.org:22/<C:\Users\Ptanwar\odi>
or
ssh://ptanwar29@altssh.bitbucket.org:443/<C:\Users\Ptanwar\odi>
jredmond
February 20, 2018
One or both of those should work, unless you have a firewall or something blocking those hosts or ports.
Hi I have tried both getting error
ODI-12436: Unable to connect to Git remote repository with the information provided. Invalid Remote Git Repository.
ssh://Ptanwar29@bitbucket.org:22/odi
SSH test result
ptanwar@YVW-R90PJ35V MINGW64 ~/odi (master)
$ ssh -T git@bitbucket.org
logged in as Ptanwar29.
You can use git or hg to connect to Bitbucket. Shell access is disabled.
location of empty repo https://bitbucket.org/yvw/odi
Any input on this new error
jredmond
February 20, 2018
You need to specify the full path:
ssh://git@bitbucket.org:22/yvw/odi
pankaj kumar tanwar February 21, 2018
Hi James
Thanks for your input but still the same issue
providing screenshot for ref
pankaj kumar tanwar February 22, 2018
Hi james
can you please provide your input
Apolodor April 6, 2020
any ideas?
thanks!
