I am new to bitbucket and I downloaded sourcetree but when I start installation it asked me to give it ROOT URL and I gave it URL in following formates but it said "Invalid URI: The hostname couldn't parsed."
1. https://<username>@bitbucket.org/<repo_owner>/<repo_name>
2. https://<username>@bitbucket.org/<repo_name>
Can anyone help me please
Hi Mohammad,
Try without the <username>@ portion. It should use your configured Bitbucket Cloud account at that point.
Hope that helps,
Brian Ganninger
Senior Mac Developer, Sourcetree
Why is it "Try" how about just provide the definitive answer?
Surely there is a definitive answer?
What is the URI when using a bitbucket repository. is it
https://bitbucket.org/<repo_owner>/<repo_name>
or
is there any need for the port? (:7990)
What is the username (i.e. the bitbucket profile username?) or the Atlassian account address?
Because depending on the choices I can get : 'Invalid URI : The host name could not be parsed'; 'Failed to check login for user [repo_owner]';'Failed to check login for user [repo_owner] : The URL https://bitbucket.org/<repo_owner>/rest/api/1.0/user/<repo_name> returned "Not Found"'
