My repo is structured like this:
Repo header
| - src/
|-bitbucket-pipelines.yml
|- my script.sh
I am trying to copy artifacts generated in my target/ folder to azure vm using azure-vm-linux-script-deploy.
myscript.sh looks like this.
#!/bin/bash
while getopts p option
do
case "${option}"
in
p) ARTIFACT=${OPTARG};;
esac
done
cd $HOME
sudo mkdir folder1
sudo mkdir folder1/folder2
cp ${ARTIFACT} folder1/folder2
image: maven:3.3.9
pipelines:
custom:
default:
- step:
caches:
- maven
script: # Modify the commands below to build your repository.
- mvn package
- pipe: microsoft/azure-vm-linux-script-deploy:1.0.1
variables:
AZURE_APP_ID: $AZURE_APP_ID
AZURE_PASSWORD: $AZURE_PASSWORD
AZURE_TENANT_ID: $AZURE_TENANT_ID
AZURE_RESOURCE_GROUP: $AZURE_RESOURCE_GROUP
AZURE_VM_NAME: $AZURE_VM_NAME
AZURE_EXTENSION_COMMAND: './myscript.sh -p target/myjar-1.0.jar'
AZURE_EXTENSION_FILES: 'myscript.sh,target/myjar-1.0.jar'
AZURE_FORCE_UPDATE: 'true'
AZURE_NO_WAIT: 'true'
AZURE_CLEANUP: 'true'
DEBUG: 'true'
There are no errors in pipelines log. New folders are not created in $HOME dir.
Any pointers to mistake will be helpful.
Edit: In the pipeline logs I saw following error:
"extensions": [
"name": "CustomScript",
"type": "Microsoft.Azure.Extensions.CustomScript",
"typeHandlerVersion": "2.0.7",
"statuses": [
"code": "ProvisioningState/failed/0",
"level": "Error",
"displayStatus": "Provisioning failed",
"message": "Enable failed: processing file downloads failed: failed to download file[0]: failed to download file: http request failed: Get [REDACTED] dial tcp: lookup bbpipe1dsome_number.blob.core.windows.net: no such host"
Hi @nikesh ,
please follow recommendations from the Microsoft Team:
If you’d like help with this pipe, or you have an issue or feature request, please contact us:
Option 1 - Azure portal: https://portal.azure.com
Option 2 - Azure DevOps: https://azure.microsoft.com/en-us/support/create-ticket/
If you’re reporting an issue, please include:
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
