×I want to run some steps only in particular cases.
My expectation would be like:
- step:
name: some conditional step
script:
- echo "run only if the condition is true"
when: <some condition>
We don't have such configuration to set special conditions for a build to happen.
Would you mind sharing what type of conditions you would test in the when clause?
Depending on what you share for those conditions I'll be able to open a feature request for this.
If you are attempting to avoid builds on certain commits you can use the "[skip ci]" token in their commit message. Commits with that token will not trigger builds.
something like:
when: $(git diff --name-only --diff-filter=AMDR HEAD^ some-directory-or-file) != ""
I've created the following feature request for this:
Please vote on this one and add yourself as a watcher to make sure you will have any updates from that ticket. Let me know if you have more comments or questions on this matter. =]
That is great, you are welcome!
- step: name: path1 failing step script: - echo "failing path1" - exit 1 condition: changesets: includePaths: - "path1/*" - "path2/*"
Hi @Alex Popa
Could you please share me the documents or more configuration for this condition step?
Many thanks,
NAT
@NAT search for "condition", because BB pipeline documentation sucks https://support.atlassian.com/bitbucket-cloud/docs/configure-bitbucket-pipelinesyml/
At the moment, using exactly the syntax specified in the documentation results in an error that the yaml file is failing schema validation. It says
There is an error in your bitbucket-pipelines.yml at [pipelines > branches > master > 0 > step > condition].
To be precise: At least one condition is required
My step is defined as:
- step: &codegen
script:
- make ci_tools
- make proto_go
artifacts:
- golang/**
condition:
changesets:
includePaths:
- "proto/**/*.proto"
