We're trying to manage disk space on our Bitbucket Server instance.
However, even after deleting a repository, the repository folder is not deleted from the host server.
Example: Repository 'ABC' is stored in 'E:\Bitbucket_Data\shared\data\repositories\1278' and takes up 3GB of space.
After using the Bitbucket Server UI to Delete the repository 'ABC', the folder 'E:\Bitbucket_Data\shared\data\repositories\1278' is still on the disk and the files are still there.
Is this expected/intended behavior?
If so, can I safely delete folder 'E:\Bitbucket_Data\shared\data\repositories\1278' manually from the disk?
Edit for clarification:
I am not trying to delete a Project Repo. I'm trying to delete a Personal Repo that was forked from a Project Repo.
In the example, 'ABC' is forked from '123'
'ABC' is stored at 'E:\Bitbucket_Data\shared\data\repositories\1278'
'123' is stored at 'E:\Bitbucket_Data\shared\data\repositories\1248'
I only want to delete and reclaim disk space from 'ABC'
I am facing the same issue as @Patrick Chen on version 7.6.1 of Bitbucket Server.
Can someone please answer his question ?
Related to this: We have hundreds of thousands of folders in the tmp\git folder
Can these folders be deleted manually?
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
