Hi
I am using in my application the package -> aws-sdk
when I am importing S3 object from the package, the docker build in bitbucket is falling with the error SIGKILL
and I don't know why its happening, on my local machine the docker build its complete fine
Hi @naorsa and welcome to the community!
I've seen this error occur when the memory available to the docker service is not enough, so that is a possible cause.
To use docker commands in your pipelines build, you define a docker service in your bitbucket-pipelines.yml file. Regular steps have 4096 MB of memory in total and each service has a 1024 MB default memory. If there are no other services in that step, you can increase that up to 3072 MB if you add in your yml file a definition as follows:
definitions:
services:
docker:
memory: 2048
Our documentation for reference:
If a step has size: 2x, the build container has 8192 MB memory in total and services can be configured to use up to 7128 MB memory (in total).
Please feel free to let me know if that helps or if you need further assistance.
Theodora
Faced the same problem. Increasing docker memory to 2048 fixed it.
Hey Theodora,
thanks you very much, its help and the problem solved !
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
