×Can I use Bitbucket pipeline build iOS app? If not, does it support local build machine?
Hi Jennifer,
Bitbucket Pipelines does not currently support building iOS apps.
By local build machine I assume having your Pipeline hook into another machine to run some commands? That is currently not support yet either.
You can follow this issue to see when Pipelines supports this functionality:
https://bitbucket.org/site/master/issues/12753/allow-customers-to-connect-the-pipelines
Direct iOS support is likely to take longer than having Pipelines hook into other machines. Feel free to create another issue for it on https://bitbucket.org/site/master/issues
Phil
