Enable Scriptrunner pre-commit hook on project key
Dani July 8, 2020
We're on Atlassian Bitbucket v5.16.10 and have multiple repositories that we'd like to enforce the same Git policy, such as require valid JIRA issue in each commit, following a standard commit message format etc.
From what I can see it's only possible to enable this on a per repo basis.
Is it possible to enable the same Scriptrunner policy enforcement on a global or project key level?
EDIT: sorry, seems I created the question under "Bitbucket Pipelines", should probably be under "Bitbucket". I've updated the tags. Please move the question accordingly if possible.
Robert Giddings [Adaptavist]
August 19, 2020
Hi @Dani ,
Yes, it is possible to create the same policy enforcements at the global level, if you are a global Bitbucket administrator.
Please let me know if you have found the global ScriptRunner for Bitbucket functionality and this question is solved? It is located in the admin area of Bitbucket.
Robert Giddings,
