Enforce Push Author Stash Hook
Seth Carter October 23, 2014
What special case does checking the "Allow alternate email (<username>@)" check box allow for?
The obvious assumption is that it allows an alternate email but wouldn't that directly oppose the default check "Require matching email address (required)" which cannot be turned off?
Seth
Michael Heemskerk
October 24, 2014
Seth,
The logic appears to be a bit more subtle. When the 'Allow alternate email' check box is checked, the hook will allow two email addresses:
  • The one that is configured in the user directory (could be the LDAP directory)
  • The one that matches username@domain.configured.in.user.directory
For instance say that your username is scarter and your email address according to LDAP is seth.carter@company.com
Without the checkbox checked, only commits authored by seth.carter@company.com would be allowed.
With the checkbox checked, both seth.carter@company.com and scarter@company.com would be allowed.
Seth Carter November 11, 2014
Thanks Michael, while it isn't what I wanted it to be it does explain what it actually does!
