Enumerating objects: 94, done. Counting objects: 100% (94/94), done. Delta compression using up to 8 threads Compressing objects: 100% (82/82), done. Writing objects: 100% (86/86), 215.42 MiB | 2.95 MiB/s, done. Total 86 (delta 37), reused 0 (delta 0), pack-reused 0 (from 0) remote: Resolving deltas: 100% (37/37), completed with 2 local objects. remote: warning: File images/main video v4.mp4 is 85.40 MB; this is larger than GitHub's recommended maximum file size of 50.00 MB remote: error: Trace: 55afa76d3f450ff21eaa4d42e50318e0b96fdc31ce13ff8d5cca02e5deee09d3 remote: error: See https://gh.io/lfs for more information. remote: error: File images/main video 0612 v3.mp4 is 110.02 MB; this exceeds GitHub's file size limit of 100.00 MB remote: error: GH001: Large files detected. You may want to try Git Large File Storage - https://git-lfs.github.com.
Hey @will ,
It looks like the issue you're experiencing is connected to GitHub.
While we're glad to help with any questions you might have here in the Community, you'll likely find more targeted assistance for problems related to Atlassian products, especially those involving Bitbucket Cloud, in this space.
Since your issue pertains to GitHub, I suggest reaching out to GitHub support or forums for more effective assistance.
Thank you, @will !
Patrik S
