Error post installing STASH 3.4.0
sameer135 November 1, 2014
We are experiencing the below mentioned error  post installing STASH 3.4.0.
We have Git version 1.9.2-preview20140411.  Please suggest how to resolve this issue.
A fatal error has occurred
The following problem occurred which prevents Atlassian Stash from starting correctly:
  • stash.git.notfound[Stash, 1.7.6, 1.8.4.3, 2.0.2, 2.0.3]
ThiagoBomfim
November 2, 2014
Hi Sameer,
Allow me to add a few comments to Marcin's answer. Probably the easiest, and most guaranteed way to fix this is to tell Stash explicitly where your Git is installed, rather than having it search the path to try and find it.
To do so, in your STASH_HOME/shared, create a file called stash-config.properties (or edit the current one if it already exists) and add the following line:
plugin.stash-scm-git.path.executable=/usr/bin/git
The line above corresponds to the directory of your Git binary (change it accordingly). This will configure Stash to use /usr/bin/git always, rather than allowing it to try and detect the one to use as described in our https://confluence.atlassian.com/display/STASH/Stash+config+properties document.
Let us know how you go.
Best regards,
Thiago Bomfim
Atlassian Support
Dani Rodni November 13, 2014
I have git installed on my machine see below: C:\Users\USER\Documents\GitHub [master +2 ~0 -0 !]> git --version git version 1.9.4.msysgit.1 C:\Users\USER\Documents\GitHub [master +2 ~0 -0 !]>
Marcin
November 2, 2014
That git version should work, most likely Stash is not finding your git binary at all on startup. Make sure git is on the path, and that you definitely get one of the supported versions when you run "git --version" from the command line. Check the Git install instructions for Stash at in case you've missed a step: https://confluence.atlassian.com/display/STASH/Installing+and+upgrading+Git#InstallingandupgradingGit-InstallorupgradeGitonWindows And if it still doesn't work this is probably a question that's better answered by Support (https://support.atlassian.com) as they will go through the process of getting your log files etc.
