FTPdeploy not answering
Nicolas BROUET
August 19, 2021 edited
When I use my bitbucket pipeline, it's always stucked at :
+ lftp -u '$FTP_LOGIN,$FTP_PASSWORD' -e 'set ftp:ssl-allow no; mirror  --delete-first -vvv --exclude=.gitignore --exclude=README.md --exclude=bitbucket-pipelines.yml -R /opt/atlassian/pipelines/agent/build /htdocs/myfolder;quit' xxx.xxx.xxx.xxx
INFO: Starting FTP deployment to xxx.xxx.xxx.xxx:/htdocs/myfolder...
 It can stay 10 minutes here, no response, no message, even with -vvv ...
Is there anyway to know what's going on ?
My ftp has a firewall, I thought it could be the culprit, but I allowed all bitbuckets IPs with no effect.
Here is my latest yaml file :
#!yaml
image: atlassian/default-image:2
options:
max-time: 6 #Configure default 10 minute timeout
pipelines:
custom:
DeployToFTP:
step:
name: 'Deployment to PRODUCTION'
deployment: production
script:
echo "Deployment to FTP starting now"
pipe: atlassian/ftp-deploy:0.3.6
variables:
USER: "$FTP_LOGIN"
PASSWORD: "$FTP_PASSWORD"
SERVER: "$FTP_IP"
REMOTE_PATH: "$FTP_PATH"
DELETE_FLAG: 'true'
DEBUG: "$FTP_DEBUG"
EXTRA_ARGS: "--exclude=.gitignore --exclude=README.md --exclude=bitbucket-pipelines.yml"
echo "Deployment to FTP finished"
artifacts:
/opt/atlassian/pipelines/agent/build/**
Oleksandr Kyrdan
August 27, 2021
Hi @Nicolas BROUET
Thank you for your question!
Have you check if it's possible to connect to you server from bitbucket pipelines before using the pipe?
Best regards,
Oleksandr Kyrdan
Nicolas BROUET
August 31, 2021
No, I havent checked that...
How do you do that ?
Oleksandr Kyrdan
September 9, 2021
How about this one?
- ping SERVER_IP
