GIT Branch and Tag creation Using Stash
Mohan Krishnan
Hello ,
Does STASH web UI provides us an option to -
1) Create branches
2) Create Tags
3) Undo Commits
If not is there a paln to incorporate these features to Stash
Mohan
cofarrell
March 24, 2013
Hi Mohan,
Unfortunately Stash does not yet have a way to do anything of those things. That might actually make a nifty little plugin. As far as I'm aware there isn't a immediate plan to introduce that into Stash, although you're welcome to raise a feature request.
Undoing commits might be a little problematic given that unless it's the tip of branch there could be merge conflicts, which we couldn't do much about.
Charles
Mohan Krishnan
I guess we cannot view Tags as well in Stash Web GUI ?
If the branch and Tag creation facility is not inbuilt in Stash , How can we achieve this ?
cofarrell
March 24, 2013
Hey Mohan,
You can certainly view commits/files from a given tag by using the branch selector. Is that what you mean?
Creating branches/tags can be done locally on a cloned repository and then pushed to Stash. eg
git tag my_tag
git branch my_branch
git push origin my_tag my_branch
Charles
Mohan Krishnan
Thanks Charles .
Where can i find teh branch selector for a given tag ?
cofarrell
March 24, 2013
When you're viewing files or commits there is a branch selector up the top-left, where you can select a branch or tag to change the current view.
Charles
Mohan Krishnan
Thanks Charles , I will try out the stuff as you indicated.
Can we push/merge a branch to another branch using Stash ? I want to avoid the usage of pull requests and additionaly want to attach a commit messages with the push/merge operation.
Thanks again for all the help
cofarrell
March 25, 2013
Hi Mohan,
You can certainly do that. In Git you have to think of branches more as pointers or named references than a heavy 'branch. So creating a branch on another branch is as simple as "attaching" another pointer.
I recommend reading GitPro for more information about how Git works. I've found it helps make using Git a much more enjoyable experience.
Charles
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
