Get the commit messages from bit bucket using the Bit bucket API
Naga Priyanka Chilamkurthi
March 24, 2018 edited
Hi Folks, We have a requirement to get the list of commit messages of a particular release branch  from the EDP-Bitbucket using the API and put it in a word document as a part of the Release Notes automation. Is there a way that i can generate the API key or suggest me how can i get these details. We are using powershell.  Please excuse me i am very new to automation and also the IT.
Michael Walker
April 10, 2018
Hi Naga,
I'm happy to report that there is an API endpoint for exactly that. It will retrieve the commit details for you between 2 commit IDs allowing you to specify the start and end commits of a branch, thus retrieving only the commits from that branch. For example:
curl -u <admin_user> -v -X GET -H "Content-Type: application/json" "https://bitbucket.mycompany.com/rest/api/1.0/projects/{PROJECT_KEY}/repos/{REPOSITORY_SLUG}/commits?followRenames=false&ignoreMissing=false&since={START_COMMIT}&until={END_COMMIT}&merges=include&withCounts=true&limit=1000" | python -m json.tool
 As you stated that you are using PowerShell, ensuring that you install Git with Unix tools will allow you to utilize commands like curl used in the example above.
I hope this helps!
Best Regards,
Michael
