Hi there,
Simple question today. Does git flow work within Stash?
Hi Doug,
Yes it does as gitflow is merely a convention that doesn't require any particular support on the hosting side. Something that is related and might be interesting for you is http://blogs.atlassian.com/2013/05/git-automatic-merges-with-server-side-hooks-for-the-win/ that helps to ensure that the various significant branches get automatically merged.
HTH,
Stefan
You may be interested in the Atlassian blog article, "Git Flow Comes to Java" by Jonathan Doklovic.
There's also Atlassian's tutorial on git-flow.
